Boobie Trap
- Feb 21, 2011
- 122
OK, just changed the oil in the out drive a couple of weeks back.
The oil in the reservoir on top of the engine was filled. It is now empty. I have filled it twice and each time with about ten minutes of running, it is empty. I realize that I have a leak but it is not in the bilge nor do I see any escaping in the water in the slip.
Could it be that it is blowing out the lower drain screw when under pressure? There is not oil observed anywhere else and it makes it hard to track down. I am hauling the boat out Friday to see but thought I would see if any ideas are out there!
Thanks.
Thanks.
