This is a sequel to my post last year. I bought a, '86 85Hp Force 1 1/2 years ago and put it on the water early last season. It ran great and I used it weekly to go fishing and cruising on the river. About halfway through the season though, my son had it out with his friends tubing and wakeboarding. They weren't paying attention and drained one of the tanks empty. After switching tanks and starting it up, it started missing and wouldn't idle without revving it in neutral and then quickly jamming it into gear. Since then, it hasn't run right. I cannot get the 3rd (bottom) cylinder to fire. Time after time (repair after repair) I took it on the water after that only to find the top two plugs carboned up but the bottom one shiny clean, and no water droplets on it.
Here is a list of what I have done to try and fix this problem:
- Checked compression 120 - 120 - 115
- Rebuilt the carbs twice
- Replaced the reed valves
- Replaced the head gasket
- Replaced the CD Module and Coil
- Verified the timing is correct (static)
I started it up on the muffs today after completing most of this during the winter. Same thing!! While it's running (roughly) I pull the bottom plug wire off and the engine speed / tempo never changes. I've got a good 1/2" spark jumping from the screwdriver to the plug. And when I'm done running it, there is a rainbow in the water running down the driveway from all of the unburned gas so I know it's getting fuel. I can run it on one plug at a time with the other two removed and grounded and the bottom cylinder one is the only one that won't run solo.
What else is left? I have compression, gas, timing and fire!!!! What am I missing here??
Thanks in adavnce for any help. I love iboats!
