outboard bleed fitting 22-15133 at bottom of crankcase
Bt Doctur
This fitting is leaking thru a very tiny pin hole in the fitting itself. Pictures do not show threads on the new part. How to remove and install the new one?
Thanks
Faztbullet
It is pressed in..use pliers and pull and twist out and add thin film of blue Loctite to new and tap in.
