I'm repairing a '75 Mercury 1150 (in-line 6) Outboard due to burned piston in #1 cylinder. I disaasembled the powerhead and upon inspection of block and cylinders found cracks in the alum block between cylinders 3,4 & 5 right where the locating pins for the main bearing/reed cage are located. Have any of you emcountered this before? Is it repairable or is it scrap? I have a close-up photo available if it would help.
