outboard bolt pattern dimensions ??
roscoe
Need to verify bolt pattern measurements.
Top holes, 12 7/8 inches apart
Bottom holes 9 7/8 inches apart
Top to bottom holes, 8 inches
Top holes should be how far from the top of the transom?
tashasdaddy
Re: outboard bolt pattern dimensions ??
it depends on the engine, especially the order ones, as there was no set pattern.
roscoe
2001 Merc 50 hp ??
roscoe
Found an old bracket in the garage, measured it.
Yes, the above dimensions are correct.
samsam
What's important is where the cavatation/ventilation plate is in relation to the bottom of the hull. Prop the outboard on the hull, get the plate right and use the motor mount as a drilling guide. Sam
roscoe
Thanks samsam.
I am not actually mounting the motor on a boat, but I am trying to build a motor stand. Didn't want to drill the holes too low in the 2x12, that it would interfere with the top of the motor mount.
Maybe I should just wait till I get the motor home, before I drill the holes.
