I run a 1998 Force 120 on a Bayliner Capri. Normal running no problem but left at idle the overheat alarm sounds after a few minutes.<br />Attempted to flush using usual clamps but no real water jet from the tell tale and again engine began to overheat.<br />Suspect water pump/ impeller (previous owner left it in seawater) but have no manual to follow.<br />Does anyone know the procedure for checking and if necessary replacing the pump / impeller - or any other ideas what problem could be?<br />Workshop diagram of engine would be helpful also any advice on prop type as i intend to do slow river work as well as sea & lake skiing.
