Outboard Dual Cable Tilt-Tube adjustments
evanrude
Hello,
Can someone please help. I am replacing the Tele-Flex Rack and Pinion Dual cable steering on my Bass boat and need to know how to adjust the tilt tubes for the steering.
The Motor is a Yamaha 200hp.
rodbolt
Re: Outboard Dual Cable Tilt-Tube adjustments
contact teleflex with the model number of your steering system.
Yamaha had nothing to do with it and you will find no information about it from yamaha.
usually the lower cable is adjusted as nessasary by the second steering cable tube supplied by teleflex that is bolted to the front of the engine.
same as merc,honda,tohatsu,jonny rudes and all others with aftermarket steering.
