Outboard Engine Troubles & Questions
bahoman
How much is it worth? Anyone?<br />Johnson Sea Horse 10hp. Model: OD-17R <br />Serial: 1452811.<br />Locked up. Only missing the tiller/throttle handle.
Trent
Re: Outboard Engine Troubles & Questions
I believe that should be QD-17R which is a 1956 model. Its missing parts and locked up..100-200.00 for a parts engine. My thoughts only. Worth more if you have the fuel tank that goes with it. They were a little different than today.
alcan
Hi B.A.<br /> Please don't be offended. It sounds to me like all you have is a pile of junk. Now one man's junk is anothers treasure. The value of your junk will have to be determined between you and the guy the needs the parts. Since these models are fairly common and most of yours is shot, I wouldn't hold any high hopes.
