Outboard Height on Jackplate?
kmurphy75
I have a 19.5' Nitro with a Yamaha Vmax 150 TRP on a 6" jackplate. Right now I am on the 3rd to bottom on my engine mouting holes.I still have plenty of water pressure so I was thinking about going up to the last hole but Don't know if that is ok? I thought it might put to much stress on the transom or jackplate? I still have a bit over 1" on the jackplate that I could go up but the adjustment screw is frozen so the jackplate is not an option.<br /><br />Thanks
JB
Re: Outboard Height on Jackplate?
Ahoy, Murph.<br /><br />Welcome to iboats. :) <br /><br />The idea of a jackplate is to raise the engine and prop as high as possible without exposing the prop or the water intakes to air and without prop ventilation in sharp turns.<br /><br />Your jackplate moves the foot farther away from the transom and gives the water room to rise before it gets to the foot. That means the anti-ventilation plate (usually misnamed the cavitation plate) can be raised anywhere from 3" to 6" higher than level with the bottom of the transom.<br /><br />The best rise ("X" dimension) is found for your particular boat, engine and prop by experimentation.<br /><br />Good luck. :)
kmurphy75
Thank you for the welcome!Sorry I might not have asked the question right. Since I can't move my jackplate I have been using the engine mouting holes to raise the motor. I want to know if there are any problems with raiseing the motor to the last hole or would there be transom or jackplate stress problems?
JB
If you can't adjust it vertically it is not a jackplate, Murph. It is a setback plate.<br /><br />If you raise it to the top hole you are much more likely to experience ventilation and cooling trouble than transom or setback plate trouble. Just raise it one hole at a time and test drive it.<br /><br />However, if you are overpowering the boat or if your transom is weak ignore everything I said. You are already at risk.<br /><br />Good luck. :)
kmurphy75
It is a Rite-Hite jackplate with a frozen adjusting screw so I can't move it. The transom in not weak nor is the plate but I don't know if mounting the motor higher on the plate is a problem?<br /><br />Thanks,<br />Kevin
steamboatwilly
Would it not be easier to fix the jackplate instead of wrestling that big ole motor?
kmurphy75
I would have to buy a new one since the welded nut on the end came off and I don't feel like brining it to a welder and then possible break it off again trying to un-freeze it. I jack my tailer down put the engine skeg on a board take out 2 of the bolts and then raise the front of the boat until the holes lineup. Takes me about 5min to move the bolt holes.
