Before venturing unbolting and moving OB up, need to determine by visual inspection where is water flow passing by through lower leg. With weight evenly distributed, trim OB well for hull to run parallel to water level at speed. If not it's a wild guess playing moving OB blindly, those OB's are quite heavy, without a lift or extra hands you're done...
Ideal max prop thrust is achieved when water flow at speed skims right under small upper water defector plate (dotted yellow line) and through sharp edge angle of attack , don't go over or under marked red X's. Report at which height was flow passing by ?
Just dial water flow at speed to skim as indicated, forget all about if middle water flow exiting middle hull is round, square, flat or whatever shape is it. Middle hull matters, side doesn't matter.
Happy Boating
