Second time this has happened. My merc 175 outboard, 92'model will start, idle low 650rpm and run but max rpm under load is 1700. 36 months ago this identical thing happened and the mechanic said the power pack was defective. The motor ran fine in the morning. I started it to go out in the afternoon and the problem occured. If it is the power pack, what made it go out again. voltage high.........any suggestion welcome. Is this easy to change myself??<br />thanks<br />gary
