Outboard loses prime, unless I stand the tank on end
Epitome
Really weird problem. I couldn’t get the fuel to prime the motor. No matter how I tried, the bulb just had air in it. Then I stood the tank on end, cap and breather up, fuel line at the bottom……and it primed. I thought I was done. I got out on the water and the engine died. Bulb was not primed again. I stood the tank on end and it ran fine until I set it down flat like it should be. Any ideas?
Epitome
Sorry, this is a very low hours 2005 25hp two stroke
tphoyt
I have found that sometimes the tank vents don’t always vent. Try loosening the cap or check the pick up tube inside the tank and see what you get.
Epitome
You’re drawing air somewhere I’d say
Right, I do understand that. Just strange that standing the tank on end solves the problem. I thought it might be a tell tale sign of something simple.
I think it is simple.----Some of these tanks today have ---JUNK----pick-up tubes inside.
Chris1956
Sometimes the fuel pickup tubes get a hole in them. When the fuel level gets below that hole, they suck air.
Of course, it could be your "run of the mill" air leak in the fuel line.
  • Like
Reactions: KJM
KJM
I agree with hole in pick up tube, tipping up the tank covers the hole with gas. Engine would probably also run if tank was full.
tpenfield
So to do that I unscrew the fuel gauge assembly and pull it out, right?
You might be able to get a view of the fuel pick-up from the cap fitting itself. Perhaps no need to take things apart. It seems like the fuel pick-up is not laying on the bottom of the tank.
Does the fuel system prime if the tank is fairly full?
Epitome
Took it apart and the pick up tube has come off inside. This seems to answer all my questions lol
No surprise to me.------I refuse to use a plastic tank in my boat.-----Give me a steel tank made by OMC in the 1960's / 1970's ----Just good stuff not affected by the sun !!!
