I have a 21 foot open console boat that originally came with an inboard. I removed the engine and would like to fit an outboard. The boat has a strong full transom (no notch, no motor well) which I would like to keep. The transom is 33 inches high. I have no outboard yet and would not mind getting a 30 inch shaft motor, however this would still leave me a couple of inches short. I am thinking of a hydraulic jackplate. My question is this - what can be the least setback jackplate I can use to be able to lift the motor (probably a Yamaha 225 or 250) so that it can then be tilted over the transom? Basically I would not like to move the outboard too far back from the transom for aesthetic reasons so I would rather work with a six inch setback than a ten inch one.
Is there any source I may check to see the curve (?) the lowest (transom side) part of the power head makes as it is tilted?
