Outboard Removal
Laker6
Any advice on the best way to remove a 75 Hp. Mariner outboard? Can I lay it on it's side/back while I replace transom and stringers? What would the approx. weight be?
Thanks for the help!!
oops!
Re: Outboard Removal
hi laker......welcome to iboats...
hang on.....gotta get some links for you....
chime in guys
oops!
we generaly use some sort of a crane to lift motors......however a 78 hp....two people can lift it off and drag it around.
as far as storage....
this is the method we like.....http://forums.iboats.com/showthread.php?t=525609
but laying it on its side...or standing it up and leaning it on something, while not preferred and dangerous....can be done.
JDA1975
I used a 2 ton come-along secured through a 6 inch ceiling rafter with a 4X4 across 5 rafters to distribute weight, so the eye bolt went through 10 inches of wood and spread out over 5 rafters, easily held the 300lb motor (mine was 90HP) Which ever method you use, be careful! the stand is great, easy to build, and using a hoist method 1 person can do it by themselves
ErikF
Best method is to remove it with some type of crane/hoist and build a stand for the motor to be kept on.
With that said I've removed motors as large as an Evinrude 115 with a second person helping and have laid motors on their sides (gently) with no ill effects.
Laker6
Gotta love this board! 4 great replys in under an hour. :)
Thanks
Laker
rheagler
I know it's a little late but I would like to chime in with a thumbs up for that stand. If you have a miter saw and even mediocre carpentry skills you can build it in less than an afternoon. Two healthy strong guys should be able to lift the motor from the boat to the stand if you don't have a hoist. Just put the stand as close to the boat/motor as you can and move from 1 to the other. A third person would be helpful for guidance/alignment, but not a necessity.
