outboard storage
bullredd
Hi, guys and gals. I have a 6 hp 1970 evenrude that i have not ran since i bought it used 6 months ago. If i ran it tommorow for a few hours and set it aside for another 6 month, what should i do before storing the ouboard to insure it to function properely the next time i needed it. <br />thanks in advance for any guidances given.
rickdb1boat
Re: outboard storage
Bull,<br /><br />Do just as you would for normal winterizing. Treat the fuel with stabilizer, drain and refill lower unit, fog the engine, Ect. Here's a link:<br /><br /> web page
phatmanmike
where is it gonna be stored?will it be in a climate controlled enviroment.. will it be in a shed, will it be in your garage? by the way, you live in florida , as do i , so why AREN'T you running it.. i have been out 4 times in the last 3 days
bullredd
Thank RB.<br /><br />Phat- i will be storing it inside my house. I know the weather is great, but i haven't had the time to get out. I was thinking of going sometime this week to the local canal and trying to catch dinner.
ED21
Master Chief Petty Officer
Be sure to run it enough to get the stabilized gas into the carb. After 6 months I would refill w/ fresh gas first. I agree w/ phatmanmike, the temperature has been in the teens & the bay is covered w/ ice & all I can think about is getting out on the water. Florida always sounds nice this time of year. :cool:
bollard
Fuel stabilizer is great stuff (especially the OMC brand IMHO) and should be added to the fuel. You are lucky with the 1970's model. I never had a clogged carb except the rare stuck float valve on my 6 HP which I ran in salt water without a cowling for 15 years! Upgraded to a "new" 1990 model about 4 years ago and the dang carb needs rebuilding anytime it evaporates dry, usually after sitting in Florida heat for about 6 months. Anyway, on the old 6 HP I ran the carb dry before storage and it worked fine, on the "new" one, I choke it to stall while flushing, squeeze the fuel primer bulb hard, leave the choke out, and put it in storage. This seems to work. I really wish I could fit the old 1970's carb on the 1990 motor.
