outboard won't start
djcally
Mercury 45, power trim. classic 50
serial = 9459899.
My outboard is having starting problems.When i turn the key it just clicks. I have checked the starter, and seems to be working fine. I assume the square black bit above the starter, is the soliniod. I also checked that, and that also seems to be fine. Althouh i have tried to bridge it with the starter and it still won't kick in. I get a spark or kick for a split second then when i try again i get nothing. I am now at a loss as i don't have a manual. I can pull a car engine apart but as i am finding, out a boat can be very diff. I have also changed the spark plugs. still just a click at the solinoid. Could this be the problem. A new solinoid required.???
Kind Reards, Lee Callahan
latin monkey
Re: outboard won't start
could be a loose connection at the solenoid. the bolts tend to loosen up or strip. try to tighten the connection and if that doesnt work a new solenoid would be around $20
grandpaclint
find out the easy way,,,,just run a + jumper to the starter, if it cranks its the solenoid, if it wont,,, its the starter
djcally
tried both and renewed the solinoid today.. still clicking... ive put a post.. im thinking these is a kill switch somewhere under the boat.
