Outcome on my 4.3 Heads Please help!
JasonGS
I just spoke with my mechanic and I was told I have 2 cracked heads along with sunken valves im unsure if I should go threw with the repair thats going to cost me $600.00 or should I get replacement new heads? Thanks in advance..
this is the number I got off my boat.. 434APRJVN 1993
10235359
JasonGS
Re: Outcome on my 4.3 Heads Please help!
I also read that there are 2 different heads with the same casting number...
The 10077626, 14099064, 10240209 or 10238181 castings were used, but be sure to check them over carefully because there are two versions of the 10238181 and 10240209 castings with an important difference. In ’92 and ’93, they came with an 8? top angle on the intake seat and a 75? throat, but that was changed to a 30? top angle with an 80? throat in ’94. Separate the 8? heads from the 30? heads and use them only on the ’92 and ’93 engines.
I dont know which one I have nor do I know how to check them..
81 Checkmate
Is the mechanic replacing with new or recondition heads and installing all for $600.00?
Cracked heads can not be repaired. They are toast
If he is replacing i personaly think its not a bad deal!
Just to have a set of heads redone is around $200.00
The question is......why do both of the heads have cracks....If its freeze damage i would be checking the block/manifolds/risers ect......
Good Luck!
JasonGS
I don't know why they are cracked.. I just bought the boat.. Not installed just fixed..
81 Checkmate
Ok i see....You took the heads to the mechanic to have them checked....right?
$600.00 to repair cracked heads....I think the mechanic is on crack! The only way to repair them is by welding or JB Weld and i wouldn't go there.
Need new or redone good heads...You can buy them and install yourself for less than $600
90 percent of the time.....when a marine engine head cracks....is becouse it was improperly winterized and it frooze!
I think you have bigger issues with your motor than you think.......
Tell us the whole story and we can point you in the right direction.
JasonGS
When I bought this boat it had a weird knock which the guy didn't know what was wrong and he ran it for 2 years with it knocking... I took apart the motor to find what my issue was and I found that it had a bent rod along with a sheared off stud... Got that all fixed ran great then I took it out on the water and the carb over flowed and I had to crimp the tube that supplies the gas to rear of the carb... That wasn't a big issue just rebuilt the carb then I found this new knock that showed which happened to be due to low compression hence me taking the head off again just to find out the carb had sucked a valve... The mechanic said $320 to get valves replaced... Then he came across a crack in the head... Im hoping this is the only issue its really concerning me that it can be worse than it is....
I was looking at buying these..
http://www.ebay.com/itm/29076850095...em=&sspagename=ADME:X:AAQ:MOTORS:1123&vxp=mtr
Will they work????
Will they work????
Ayuh,.... Those'll work, or throw in a new Intake manifold, 'n bolt on a set of Vortec heads,...
The Vortecs are good for 'bout a 20hp, Increase...
JasonGS
What else will i need for the vortec conversion... And I'm not sure what vortec heads and manifold will work..
Ayuh,.... Hard to say,... donno what yer startin' with...
ya need the Heads, 'n intake manifold... then a carb to match whatever intake ya pick...
If it wouldn't work, I wouldn'ta mentioned it...
JasonGS
I'm just going to stick with the setup i have now just so i don't have to worry bought buying a ton of new parts.. Thanks ...
koolhandluke
carb over flowed and I had to crimp the tube that supplies the gas to rear of the carb... I was looking at buying these..
Better check your fuel pump..Thats an overflow tube to prevent a ruptured diapham from dumping fuel into the bilge....
Maclin
I think the OP meant the equalizer tube that runs from the front bowl to the back bowl on the single fuel inlet 1810 style Holleys. That is how I took it anyway.
JasonGS
Exactly Maclin... Sorry couldn't figure out the name..
