outdirve identification help
hi i have a 1969 mercruiser outdrive with a 140 motor and need to know what model my outdrive is so i can get a new prop for it. i have tryed to look it up and have come up empty handed. :confused:
Fun Times
Re: outdirve identification help
Do you have a serial number stamped on your drive?
A prop should be pretty easy to find as the size on the mercs has not really changed much over the years.
As a starting point, here's a list of drives over the years,
http://www.mercruiserparts.com/selectModels3.asp?type_id=DRA
Do you have a prop on the boat now? if so, are there any numbers stamped on the prop? If yes, what are they?
Don S
It's a MC-1 (Mercruiser One) outdrive.
The only drive used on a 140 back then.
i found # on prop 15 1/2 R19M WC and don't they call this outdrive a pre alpha also
