I am not sure where to direct this but I am looking for a bit of help improving performance.
Boat: 1979 Gradywhite 254 Kingfish, 25 or so ft. This is a deep heavy boat for its class. I am estimating 7500 lbs with gear.
Power Steering / hydraulic trim tabs
Engine: 2009 MPI 5.7 / 300 HP
Outdrive: Alpha one Gen II, or now the SEI equivalent SE116.
Prop: 16 diameter / 13 P / 3-blade
Primary use: Off shore fishing
Problem #1: Low end steering. I cannot stay straight on the low end. Boat is all over the place with constant correction needed.
Problem #2: Occasional prop spin. Sometimes the prop just washes out like there is no water hitting it at higher speeds. If I slow done and regain plane the problem goes away.
I have tried various props from 17P-11P. I have found that the 13P gives me the best performance with the 15P a close second. The only problem I have had with the 15P is slow to plane and not enough pop when riding 4-6 ft seas.
Should I consider any aftermarket add-ons that may help with these two issues? If so, which and why?
