Re: Outdrive drain plug
throw the clymer manual away and get the OEM manual for your drive
you need to fill the drive from the bottom drain plug in the drive, be sure to remove the vent plug in the upper
pump from the bottom until you get lube out the vent hole, put the plug in the vent hole with a new gasket
remove pump from bottom hole and install drain pulg with new gasket
fill the monitor bottle - keep a quart on board to fill the monitor bottle after 15 mins of running, the level will probably drop (air bubbles escaping from the system)
keep an eye on the monitor bottle for the first few times you go out, it will eventually level off
