outdrive gasket failure
mudweiser
Just replaced the outdrive gearset on a 89 Bayliner with the Alpha 1 outdrive. On the 1st trip out, the gasket started leaking. Noticed it was spit out around the drive. Maybe i overtorgued it? Whats the torque specs on the outdrive 6 nuts and the lower unit nuts as well? Take a look at the attached pics and tell me what you think. The new gasket is already in, just waiting to confirm torque specs before i wrench on it. Thanks...
mudweiser
Re: outdrive gasket failure
Installed gasket number 2. Torqued it to 30lb and it was ok. Then i torqued an additional 10lbs to 40 lbs and it spit out the right side this time. Whats going on here? I'm ctorquing them from the center out in a cross pattern.
jerryjerry05
Are you putting sealer on the gasket? They aren't supposed to have sealer.
Are the mating surfaces clean and smooth? Is the O-ring still there? Jerry
mudweiser
Clean, dry surface, no sealer. O-ring gasket still in place.
mudweiser
Here's a pic of the second gasket. I torqued this guy to only 30lbs and it spit at 40. Also i used a different torque wrench this time around to rule that out. have another gasket ready to install, but this is a Sierra gasket w/o the built in o-ring. Any suggestions? I don't like using sealer, it seems to cause things to move around in my opinion. But then again...... Any thoughts?
Haut Medoc
As long as you lined up the six bolt holes & made sure the gasket was put on properly with the water passage o ring installed, I don't see a problem.....
However with out seeing the mating surfaces & a pic with the gasket on there before the drive is installed, who can really say what, if any, problem exists?.....
Post some pics before you install the drive.....;)
Robj
Try a OEM gasket. You would not be the first person to have problems with aftermarket parts.
Have a great day,
Rob.
mudweiser
Have a great day,
Rob.
I thought QuickSilver was OEM Brand? Either way, the Seirra gasket seems to be holding at 50 LBS. all i did different is scudff both surfaces with a 3M disc and wipe down with carb cleaner before assembly. The good outcome with this gasket deal is now i can remove the outdrive and have it back in now in about 1/2 hour. Haven't had the boat in the water yet. Maybe tomorrow.
erikgreen
I use the quicksilver myself now, but I've found an awful lot of variation in aftermarket and OEM gaskets. Maybe the ones you had weren't quite for your model of drive?
