nylyon
- Sep 2, 2015
- 16
I recently purchased a little 1997 Four Winns 170. Unfortunately, this is my first I/O (previously had an outboard run about and an inboard ski boat), I didn't know what to look for. The boat is really clean, however when I took it out on the lake it made a very loud grinding noise. I was prepared to replace the gimbal and check the u-joints when I pulled the outdrive.
Today, I pulled the outdrive off and sure enough, the gimbal bearing is bad, having lots of roughness and noise. The u-joints seem to be fine, move easily, no binding. I will just re-grease them. The u-joint bellow had water in it, so I will be replacing the bellows as well
What I did notice, is that the only gasket is an o-ring around the water passage, but nothing around the outdrive itself where it connects to the bell housing. I plan to clean up the mating surfaces, replace the o-ring but is there another gasket which needs to be replaced, should it be Permatex'd, or just left as is. I downloaded the service manual and it didn't show a gasket, or the use of permatex, but thought I would check.
Finally, it looks like the trim sensor white wire (3-wire) is broken. I will replace this, but does anyone have a picture where the wire runs into the boat?
