I was installing my outdrive today and I ran into a problem. The gasket that mounts the outdrive has bulged a bit right next to where the water inlet o-ring is located. I was wondering if this is ok or if I should pull the outdrive and install a noew gasket. If I do need to install a new gasket, can I leave the large rubber o-ring and o-rings on the drive shaft? I just changed them as they were part of the kit.
