Outdrive Help!????
adm1476
Ok here is the story. My boat is a 1981 Cruiser 21ft with a mercruiser 165 inline 6cyl engine. Last week I blew the outdrive. Today I changed the outdrive with another one that I had. It came out of a 1986 Citation with a 4cyl engine. The drive on the 1986 is an alpha 1, the drive on the 81 was a M1 (i'm guessing). The gimbel bearing , boots and shift cable are all new. Also the shift shaft seal is new. I took the boat out for a test run today, and it seemed to go ok but it makes a noise when I turn left or rt. Might even make it very slightly when I go strait, but barely noticeable. I did change the input shaft with the one from the M1. 4cyl was too long. So what could be causing this noise? Sounds like the top of the drive.Help!!!!
adm1476
Re: Outdrive Help!????
I'll pull it tomorrow, and check it. I greased them when I had the drive off they seemed fine.
Thanks
90stingray
i had mine drive off for maintenance and thought the ujoints felt good. After i had her out for a water test... they made noise too. I just replaced them yesterday. Goodluck!
dubs283
check the engine alignment
and really grease those u-joints - til it flows out past the seals
be sure to replace the drive gasket and o-rings on the shaft too
