outdrive help!
Kng15012
Merc 4.3l with a alpha one drive. When I hooked it up to the muffs yesterday. All was good in neutral. I went to engage forward and it kinda grinded while in gear. Same in reverse. But the drive spins free in neutral. I however did ease into gear. Also the motor was idling a little high from sitting all winter. Could that be the source of the sound? Or does the motor need the river water pressure?
bman440440
with alpa drives never "ease" into gear... a high idle may have a little to do with it but alpa's DO NOT LIKE to be eased into gear
alphas need to be shifted into gear with authority. the dog clutches dont like a gentle hand.
also, without the drag of water, it will grind alot
