GMTK
- May 27, 2016
- 164
2004 SX-M
I have the Volvo workshop manual and have been following it. Pulled the outdrive with no issues so far but I have a couple questions.
1. Do I put locktite on the pivot bolts? They have some yellow on them so it looks like a a thread compound was on there at one time but I can't find anything in the manual.
2. I forgot to get the O ring for the water seal tube (the smaller of the round rings) the one on there looks fine; is this a "must" replace or can I re-use the one on there now? Would take a week to get one to me via the web.
3. Is the build-up on the water passage normal? Going to gently scrape it off.
4. is it normal to have great in the u-joint bellow as seen in the attached photo?
5. The old u-joint bellow had some sort of metal ring the went around the inside from front to back. They new OEM bellow does not have this. Do I need to use this ring?
