outdrive knocking noise while cruising.
motteatoj
Hello,
I have a 1988 Bayliner Trophy with a 350 SBC 5.7L, along with the traditional OMC outdrive. It was a project boat, old engine was seized and ended up putting in a new engine. Previous owner removed the OMC 5.0 and put in the 5.7(the one that was siezed). I just got a remanufactured 5.7 that worked. I've taken it out 9-10 times now, nothing major happened just working out the kinks and testing propellar sizes. I was very impressed how well everything was going, considering without youtube it would still be in my driveway, untill this last prop change. This last time I went from a 15x19pk(wot 3700, mph 38-39) to a 15x17p( wot 4100 mph 37). I'm still testing props, were getting closer to wot 4600. This last time everything was good, maybe 4 hrs in I heard a clunk or knock, like I hit something, I looked back but didn't see anything I could have hit. It did that 2 more times during the trip. From reading what it could be and how it felt, I think the lower units gears might be slipping or something down there is failing. Does anyone have any thoughts? I replace the upper and lower shift cables with the OMC tools. It's shifting smoothly finally so I dont think thats the issue but I really have no clue. I've been looking at a replacement lower unit, either rebuilt or the new SE109. Ive also explored the mercury and volvo conversions, the last thread about this topic i found was in 2011 and just seeing if anyone has had any new ideas or new info about the SE units? I've already put alot into the boat so im not gonna go the cheapest route if its a crap choice but also realize its a 36 year old boat and need to draw the line somewhere. Im just tryna see if I need to jump on it right now or ride till the wheels fall off. Thanks guy thats the outdrive and tag on it. View attachment 411464Instaup iOS is a popular tool for enhancing Instagram engagement with real-time analytics and follower tracking. Many users look for safe ways to download and use it on their devices. You can access the app directly through https://instaupapkdl.com/, which provides the latest version for iOS. It offers features like auto-likes, story views, and post scheduling to help grow your account. Always make sure to follow Instagram’s guidelines to avoid restrictions. Overall, it’s a convenient option for managing your Instagram presence efficiently.
Been trying to figure this out without luck and don't want to just throw parts at the engine. I get a knocking like pre-ignition from 3500 and up. It is getting worse. It does it under no load tied up to dock, does it under load, does it while cruising. I have already changed the plugs and cleaned the corrosion off the cap, a new one will be here in a day or two. I am certain it is not the cap at this point. The system: 2004 Mercruiser 5.0 MPI pushing a Bravo 3 outdrive, engine serial number 0W029519 so that makes it an early MPI. 200 hours Knock sensors are like $50 or so, I spent that much on 4 spark plugs. (spendy special buggers) Should I just get one and go for it? Is the torque as critical as manuals say? One other point, this pup is packed in with minimal room to access anything, the sensor will be hard to take out and a 100% by feel job.....I might get a camera setup .............. This is now bad enough I don't want to use the boat and the dealer just doesn't have time to look at it yet.
Ayuh,..... Welcome Aboard,.... you posted this at the end of a thread in the OMC forum, I moved it to the Merc I/O forum for you,....
