I have a small oil leak coming out of the weephole at the bottom of the drive. I removed the lower unit to check it out , thinking that it was probably the shift shaft. There was no oil coming from there, but I did have oil where the drive shaft meets the top of the water pump and leaking down out of the drive. I was just wanting some advice on what it could be and where I should look first. It is a 1971 Merc 165 I6. Thanks.
Bryan
Bryan
