outdrive leak
I have a leak coming in at the bottom of the outdrive. I sealed around the edges with silicone and it still leakss. Any ideas?<br /><br />Mitch
Don S
Re: outdrive leak
Are you absolutly sure where the water is coming in at? <br />There are a lot of places on the transom sheild that could allow water to leak into the boat, so finding out exactly where it's coming in at is the first thing you need to do.<br /><br />PS: Silicone is for houses, not boats, and should never be used below the waterline.
Re: outdrive leak
would hitting debris and dinging up the prop while coming ashore a couple times when I first got the boat cause a leak around the prop??
Don S
Re: outdrive leak
Props don't leak.
Re: outdrive leak
I know props don't leak, but can water gaet thru the splines? What are bellows? I am an Aircraft mechanic and don't really know much about boat out drives. I just want to fix the leak.<br /><br />Mitch 817-714-0599
vipzach
Re: outdrive leak
There are shaft seals down there where your prop is installed. The bellows is the rubber boot that the ujoints go through, between the motor and outdrive.
Trent
Re: outdrive leak
You have three bellows on that puppy. Shift cable bellows, u-joint bellows and the exhaust bellows. Kick the outdrive to one side and look at the conditon of the "rubber hoses" (bellows) and check for dry rot or holes of any kind. Then kick the drive to the other side and recheck. You really got to find out exactly were its leaking to do the proper fix.
Trent
Re: outdrive leak
Prop seals do go bad but you will get water in the lower unit and not in the boat. Water in the boat comes normally from a bad u-joint bellows, a bad shift cable bellows or the oil seal in the bell housing.
vipzach
Re: outdrive leak
the bellows are intact with slight dry rot cracks. do the prop seals go bad? <br />That is probly where the water is coming from.
tommays
Re: outdrive leak
its a chore but it can be done at home if your not in a rush ;) <br /><br />biggest problem is all the other problems you find :( <br />
<br /><br /><br />and you do need a lot of stuff to do it right<br /><br /><br />tommays
Re: outdrive leak
Ayuh,.......... I Love that Pic...........<br /><br />Last time I did the Gimbel Housing Rebuild gig,.........<br /><br />I Needed a Much Bigger Box of Band-Aids than Your's..................... :D
tommays
Re: outdrive leak
but i have a BIG one and a littel one<br /><br />tommays
