Seaswirlstripper99
- Oct 23, 2012
- 12
I have a Volvo Penta dp sm out drive that is leaking oil. Last time I took it out it was bubbling oil out. When I trailered it. I removed the shift linkage cover and the center bolt on the gear shift was removed. Must of loosened out. I just replaced the shift cable few weeks prior. Would the bolt loose cause it to leak? Can I just change the gear oil and tighten bolt and that's it or is there a bigger issue ?
