Outdrive not shifting into reverse
Hello,
I have a 85 Mercruiser MCM140 mated to a alpha one drive. When shifting into forward all is fine. I have no reverse though, even when i remove the lower unit shifter cable from the shift assist assembly and pull the cable all the way out, still no reverse, just a clicking at the prop. Also when i tilt the outdrive up with the boat in neutral the prop will start clicking as if trying to get into gear. I think it may be a lower unit shifter cable...just want a few opinions before removing the outdrive...Thanks..
PS....the engine revs as if it were engaged into reverse...so not the interupt system.
Don S
Re: Outdrive not shifting into reverse
The shift interrupt system has absolutely nothing to do with rather it goes into gear or not.
Pull the outdrive, it's a 10 minute job, and see if reverse works at the drive.
Here is the drive in reverse. This is what you will turn manually to engage reverse. Photo by Ziggy:
