Outdrive oil reccomendation.
peejcj8
I have a VP 280 converted with a Duoprop lower.
Ive yet to change the oil in my drive. Ive had the boat 2 years and due to other maintenance issues the drive has been serviced by pros.
I was looking in my manual and it says 30W for 280, but 90W for a DP 280.
The oil in it now is green, so Im assuming its synthetic 90W.
Thanks
Eric
Don S
Re: Outdrive oil reccomendation.
GL5 Synthetic gear lube 75W90
peejcj8
Thanks Don
Wish me luck when i pull off the upper on Saturday to find my source of the grinding noise.
When I pull off the upper, can I then remove the seal and check the Intermediate bearing for water intrusion? Is this easy?
Thanks again
Eric
