Outdrive oil vent stripped threads
josh1981
So when changing the gear oil in my out drive (alpha one Gen II) the oil vent threads stripped. When I went to put the plug back in basically the threads from the outdrive came right off and were in the threads of the plug. So has anybody had this happen and can I simply use a Heli-coil? Thanks
Bt Doctur
Re: Outdrive oil vent stripped threads
heli-coil or timesert will fix it.
josh1981
So will I need to trim the heli coil to the length of the plug or can it stick inside the drive a little bit. Also the "tang" on the inside end of the heli coil, I figured I don't need to break that off since I don't want it falling into my drive. Doesn't hurt anything still being there right?
