Outdrive oil
sub2010ss
With all of the work I've been doing and hitting the lake for the first time, I was concerned about water getting into the drive. I pulled the drain and clear clean oil drained out. If I had any water it'd show at the drain, correct? Oil floats on water.
alldodge
Correct, but after running the water would show up something that looks like milk. Now your lube being clear, I take it your using something like Mobile one or Amsoil synthetic?
sub2010ss
It had settled over night. And I'm running quick silver high performance gear oil.
bspeth
I always drain it into a clear container then wait
Ayuh,.... Sittin' overnight, if water were present, you'd see water, or cloudin' of the oil when it's drainin',...
After a tablespoon it ought be Visible,....
