Outdrive Paint
rkilpa
I just purchased a 2011 Ebbtide 2200 Fun Cruiser and the engine runs great! This boat is six years old and the lower unit was recently replaced. The upper unit looks like it's 20 years old. What would cause this condition when the rest of the boat looks brand new?
bman440440
it looks like the drive is getting hot... not due to a problem just from use... when they are used hard they get hot and the water will make the drive look like that because its "cooking" off... IMO I would get a drive shower on that thing ASAP to keep it cool and keep the bearings happy... google "mercruiser drive shower"
use sno-bowl toilet cleaner and clean off the minerals
tpenfield
Looking at the upper portion of the outdrive, I think we know why the lower unit was recently replaced. Hot, hot, hot. Wonder if it was really low on oil or something like that?
rkilpa
No Title
I thought the paint was shot. Turns out it was a very heavy layer of calcium deposits. I was able to use acid and a lot of scrubbing and I was able to get it all off. Now the entire drive looks as good as the rest of the boat.
I'm pretty sure the boat was used at Lake Havasu where the temperatures are very high and the previous owner just didn't wipe down the drive when it was wet. The sun bakes on the deposits out there,
achris
More fish than mountain goat
I'd be stripping that drive and checking bearing pre-loads and gear backlashes... Something internal is making that drive very hot, very very hot.
Chris......
crazy charlie
I have see that look before.I will bet the upper was sprayed with either clear coat paint or clear antifouling paint.Looked like air bubbles to me.Charlie
rkilpa
No Title
Got the driver shower installed. Very simple principle: water forced into the tubes from the bottom with no place to go except out the holes over the drive, keeping the driver covered in water while on plane.
Thank you for the advice.
achris
Nice 4 bbl prop... Have you tried the 4bbl Stainless ones? Much nice!!!!
