Outdrive pressure testing
ralphy670
I assume that pressure testing the outdrive only tells you that the gear lube system is sealed. How can one tell if the water pump housing is leaking or not? I followed the service manual and torqued everything to spec, the only thing I did different was use Permatex aviation gasket sealant instead of the Mercury Perfect Seal.
Any help is appreciated.
ralphy670
Re: Outdrive pressure testing
Oh ya forgot to mention I did an impeller change. And the drive pressure tested ok.
Alpheus
Run it on the muffs and look for water coming from places it shouldn't...
