Hello All, first post here.<br /><br />I have a 72 Schuster (tahiti) boat, with I believe the original Mercruiser engine 3.0 140hp and outdrive. I am trying to figure out the model and year of the outdrive (Pre Alpha, Alpha1 etc.) I have the below info<br /><br />Mercruiser<br />H.P 120/140<br />SN/3357372<br /><br />Additionally I have noticed the outdrive oil is milky. I know this can be bad but I believe it is due to the vent screw not haveing an o-ring seal on it??????. I saw oil (just a little) comming out of it while I was running it on land (with a hose of course) I would like to change this ASAP. What type of oil is needed for this model outdrive? Additionally I have 1 drain and 1 vent screw, I should fill from the bottom, right?<br /><br />Also should I use a certian o-ring type seal on the screws or will any type that fits work.<br /><br /><br />Thanks
