45Auto
- May 31, 2002
- 2,842
My Bravo 3 had some nasty looking galvanic corrosion around the edges of the top cover, as well as a couple of dime sized spots on the drive. I repainted the top cover and spot painted the drive. I bought the minimum available quantities of PPG chemicals and paint to refinish per the factory specs (cleaners, etchants, conversion coatings, epoxy primer, urethane paint, hardeners, catalysts, etc) and it came to just over $200. I already had all the body work stuff (sandblaster, compressor, spray gun, etc). The top cover and drive look like new now and will hopefully last a long time.
Looks like the reason the top cover corroded was because it was never completely painted on the lower surface.
I still have about 90% of the supplies that I didn't need that anyone else is welcome to use. If anyone in the southern Louisiana / southern Mississippi area needs to clean up some corrosion on their drive and can bring their boat to Slidell we could probably do it in a couple of hours.
Keith
Keith
