Outdrive seal 12 hole
Jeff1967
Hello, I have a 1967 evinrude boat I/O 155hp. My outdrive to transom seal is leaking badly. Mine has 12 holes. All I can find is a 16 or 22 hole version. My question is can I use a 16 hole seal and just drill new holes in the transom? Amy help would be appreciated. Thanks! Jeff
kenny nunez
Your transom seal is the round one which is NLA so you will need the 313080 OMC # or 18-2767 Sierra. The 313081 support ring is NLA. You will have to fabricate one from some aluminum 1/8” X 3/4” flat stock. Also the stainless worm clamp is NLA so be careful not to over tighten it or you will be buying a lot of worm clamps and “Daisy chaining“ them together.
Sorry for the late answer I was out of town.
Jeff1967
Thank you so much for the info that helps alot! Jeff
