Re: Outdrive still won't come loose
It seems like I'm going to rip it out of the transom.
Well,<br />
IF that Happens.........<br />You Needed a New Transom AnyWay............
<br /><br />To Start,<br />Try the Block of Hardwood,+
THROW it to the Down position............As
Hard as you Can..!!....<br /><br />Using the rams will in fact lift it a bit, <br />But is Also Pushing Out, as well as Up.......<br />Actually it pushes Out, More than Up....(the rams are Horizonal, not Vertical)<br />And,<br />If you position a block of Hardwood at the Top of the Drive,+ Jam it against the Transom Shield(so it Can't go Up),<br />All the pressure will be Out, Not Up......<br /><br />I Think you need to be Much More Forceful......<br />A Block of Hardwood,+ a BFHammer.....<br /><br />The Truck,+ Tree Is Extreme,<br />But,<br />I've Been There, Done That.......................
