Outdrive swap?
TCATTC
I have a 20' Fisher aluminum deck boat with a 4.3 Alpha one gen II drive. I need to replace my upper drive, I already have a 3.0 (1.94) drive and a V-8 (1.47) drive. Would it be possible to use one of these with a prop change, or is it just wishful thinking? Thanks in advance.
Bt Doctur
V6 is usually the 1.84 ratio and both drives would have to be from GEN II`s.
Ayuh,..... Welcome Aboard,.... You can try either one, but usually there ain't prop pitch enough to make up the differences,.....
Props generally run from 15"s of pitch, to 23" of pitch,....
nola mike
I was able to up-prop enough on a 1.97. 170 hp, originally 1.84. What pitch are you running now?
TCATTC
Actually I don't have a prop on this boat yet but I have a 17, a 19, and a 21 prop I can try. I don't know which one to start with.
thumpar
What is the reason for the upper replacement? It it is because of bad gears then you should just replace the whole drive.
TCATTC
I acquired this boat without a motor and drive, just the gimble housing. I have a lot of parts and am trying to put together something.
