Outdrive switch bypass
TheSeasLife
My port outdrive will not come up with trailer or thumbs buttons. Can I bypass switch by running a loop somehow at pump? I need to get boat on trailer and need drives up before tow...
Re: Outdrive switch bypass
Ayuh,... Jumper it right On the pump...
If it's a wiring problem, it'll work...
If it's the pump motor,... You're outa luck,+ will have to manually bleed,+ lift it...
TheSeasLife
I know the the relays(?) on pumps are good. It is switches at helm. Do you know which connection to touch? (I believe I will go from pos. to top relay but which connection)
rjwoodrome
diagrams are avalable in the I/O section in the stickies section thats where I was able to down load all the manuals for my engine, outdrive, and the trim as well. complete wiring diagrams are there too..:)
rjwoodrome
look in the DIYS section they are in there. lota of good stuff!!!:)
