outdrive upgrade
larson 98
I have a 1998 larson 226lxi,5.0 gl with volvo penta sx 151:1 ratio,can this be changed to to dp-e 168, if so what props should i use
Don S
Re: outdrive upgrade
Not with the DP-E, it's a completely different type of drive. But you can change to a DP lower unit for the DP-S drives. You need a 1.98:1 gear ratio in the lower.
