gandgracing
- Jun 6, 2014
- 6
So I pulled outdrive after noticing the gasket was leaking and it was taking in water to the driveshaft. Replaced gimbal and seal behind it. Tried putting outdrive back in and it will not go. I aquired an alignment tool and I cant even get it to go into the engine spline. I removed the new gimbal and the tool still wont fit into the engine side. It seems that the collar between seal and motor could be the problem? Could my engine alignment been that far off?
