Outdrive will not lower
mr. b
I have an outdrive in the up position. It will make a noise when you push button to go down but it will not lower. If you push the button to go up it makes the noise like its up to the limit. I have unhooked the hydraulic lines to the rams and stood on the outdrive trying to lower it and it still will not go. Any suggestions??
Bt Doctur
Re: Outdrive will not lower
try reversing the 4 hyd lines at the back of the boat
