Outdrives
IS it hard to rebuild outdrives and is their a book anyone could suggest where I could learn how to do this. Or any other suggestion . Do you need any spical tools thanks
JFLS40
Re: Outdrives
I am in the process of rebuilding a 1977 MerCruiser 120/140 (pre-alpha) that has some broken teeth on upper gears. There are some special tools that would help but I was able to dismantle my upper unit without them. There is a spanner wrench that will probably be necessary for the lower unit but it is kinda pricey. If your mechanically inclined you can probably disassemble the upper no problem. I believe you will probably need a dial indicator and some specs to properly rebuild the outdrive. This is my first boat and I am learning as I go. I haven't bought any manuals yet but am using the info on www.mercstuff.com <br /><br />If you want, I have some digital pics I took and can explain what I did to dismantle the two units and remove the gear assemblies from the upper.<br /><br />Only thing I am not encouraged about is the cost of these parts. It is outrageous. A shaft and gear and bearing cost from 200 to 400 and probably even more for some of the bigger outdrives. The biggest drawback I can think of is buying the parts and not rebuilding correctly and finding broken teeth and messed up bearing after you spend so much money.
tommays
Re: Outdrives
it really depends on your skills there are shop manuals made for prety much every drive and each one needs special tools to do most repiars.<br /><br />i find the hardest part is get it apart with out breaking it(water can play hell sticking parts together) after that it is no harder than any other machine repiar <br /><br />tommays
achris
More fish than mountain goat
Re: Outdrives
Three pieces of advice if you want to rebuild a leg.<br /><br />1) get the manual<br />2) get the manual<br />3) get the manual<br /><br />Did I mention that you should get the manual?<br /><br />If you post the leg serial number or the year I'll give you the Mercruiser genuine manual number.<br /><br />Chris..........
