- Mar 8, 2009
- 42,649
Not the same question as in previous threads, but the end result is getting to the same point. Will not be doing any retransmission for others, only self use so the FCC should not be an issue
Looking for knowledge to do it or figuring out what other forum would be best to post the question
Want to setup an Over The Air (OTA) DVR to record shows off a local antenna. Need to be able to communicate with the DVR via the net, and be able to stream or transfer the files to my home for watching later. The DVR will probably be a server with video capture cards and hard drives. The communication via the net is the issue as I see it now.
