alley mechanic
- Apr 15, 2011
- 100
Hello all, i have two questions about the temp and warm up switches on my 98 115 intruder so here it goes when you replace the switch on the port cylinder bank the clymer manuel says to coat the outer part of the switch with omc gasket sealer not the top when i pulled mine out to check it it had nothing on it from the factory im the original owner of this engine , my omc manuel says nothing about the instalation of the switch, now the second question are the temp side of that switch for the quick start prone to go out or work intermiditley causing the timing to advance when it shouldnt after the moter reaches 105deg any information will be appreciated.
Thank you
alley mechanik
Thank you
alley mechanik
