mike90force
- Sep 5, 2009
- 1
i ran into shallow water and filled the impeller with sand and peples. engine over heated, i removed the bottom end and replaced the impeller and removed all the pebles. still over heats. no water comes out of the tell tale. removed the thermostat and tried it with it removed. can get a bit of water slowly if engine is reved up. not sure what i did wrong? and info will help.
