over heating engine at idle
ischart
ok guys ck this one .. new engine ,new manifolds , new rec pump, new impellar, new bellows,new thermostat and still overheats at idle.. 210 deg. cant drive in no wake zone .. 1500 on up temp drops to 155..
CAPTKEV85
Re: over heating engine at idle
I had the same problem overheating at idle. I changed everything, then found out by taking the drive off sticking a garden hose in the water intake tube, and then go squirted in the face because there is a copper tube that connects the hose from the back of the bell housing and the goes throught the transom to the other end. That copper tube was rotted. Check yours maybe thats the problem.
Don S
What was the condition of the upper housing and pump base of the raw water pump in the drive.
ischart
all new , 8 degreees on timing ,new ball ck valves , gonna back flo ck the water line , could old risers cause this issue?
ischart
its a 94 searay 200 signature ,alpha one gen 2, four barrel carb. all marine parts , when put ball ck vaves on temp goes to 210 and stays there never drops.. laser cked temp
ischart
ok i back flow cked .. came up clean and smooth flow . back flow ckd the riser lines . same clean and smooth.. totally lost now
ischart
hey there don you may know the engine builder u.s.engines in wa.
Pete104
New engine? Of what type? Was this a total tear down or buy it from somebody? Yes, the risers could, BUT! Not an idle. Check the assembly of the "thermostat Hsg"!
Ayuh,... Just the wrong riser gaskets could do it...
Got a serial # so Don can nail down Exactly what you've got,..??
ischart
ya serial #for engine OF 142512 5.7 thunderbolt ign. put on new restriced gaskets on risers
ischart
fresh water lakes only 16 hours on new 320 hp long block from u.s.. marine . gonna double ck total advance on engine.. but she does'nt knock at all.
dubs283
im going with riser gaskets, you probably need the four slot, especially if you have riser blocks
Don S
post a picture of your cooling hoses and how they are routed from the thermostat housing, include a shot of the thermostat housing so we can iD it. I have seen some with your problem that were plumbed wrong after replacing the engine.
ischart
good morning will do don thanks allot.. need to take care of the wife and mom... then ill be all over it.
ischart
ok ckd hoses they are correct. ordered new water pump ,water tube , sleave , seals ... etc.... so will let ya know ... iboats will deliver on fri. 13th woooohoooo
Don S
What, no pictures ?????
ischart
ok all better .. cant narrow it down what was the problem . but i took the easy way out and replaced every cooling part down to the water pump bolts .. a piece of mind knowing it is all new is priceless and and all quicksilver parts...thanks iboats and jerry in florida .
